COMPLETE 40mm AXLE ASSEMBLY WITH BRAKES. EVERYTHING you need to bolt-on and go - including ALL the nuts and bolts WITH ANODISED COUNTERSUNK WASHERS!
High Quality anodised go-kart parts.
Are you considering a cheap ATV setup to use for your project? Here are some of the potential pitfalls of using ATV components instead of quality Go Kart components:
ATV: Splined shafts and welded hubs
- Parts are usually cheap chinese components designed for small trikes which aren't designed to go fast and won't withstand the forces your project could endure at times of high demand.
- hard to find replacement parts
- most splined hubs do not fit standard go-kart accessories,
- can't relocate the hubs for placement - you'll need to build your project around the axle
- can't fit alternative sprockets - you're stuck with the sprocket and gear ratio you get and you'll need to hunt down a compatible clutch (if it exists) - these are often too tall and willl destroy your clutch
- Can't re-size axle shaft - you're stuck with the axle shaft length you get.
GO KART: Standard keyed shaft
- All parts are designed for high speed race use - so they are safe even under the most extreme conditions.
- easy to buy replacement parts,
- hubs fit standard go-kart parts (you can buy them anywhere!)
- easy to change hub locations (position the axle hubs around your project, instead of making your project fit around the axle)
- Fit any go kart sprocket and get your gear ratio right (you'll have full access to many different pitches and sizes)
We have decided to make life easy for you and help you out with comparing the prices too. In the brackets ( ) you'll find comparable prices on the net including postage so you can see how much you'll save by buying the whole lot from us. Plus, I bet there's some parts in there you won't get anywhere else!
1x 40mm Axle Shaft ($120
1x Drilled Brake Disc ($80)
3x 40mm Anodised Sprocket Carrier/Hub ($165)
1x Complete Hydrualic Brake System ($100)
18x ANODISED Countersunk Washers, 18x Countersunk High Tensile bolts, 18x Washers, 18x Nyloc nuts, 18x High tensile bolts for Sprocket Carrier ($72)
Axle Length: 1050mm
Keyway locations: from end to end:
@ 10mm->75mm
@ 120mm -> 185mm
@ 350mm->400mm
@ 740mm->790mm
@ 975mm -> 1040mm
Brake Disc Thickness @ 3.5mm
BRAKE SYSTEM
Hydraulic
700mm Lines
Suits Included Disc
SPROCKET HUBS
Brand New |
