Homologated Torini Clubmaxx Noram GE Ultimate Clutch
Suits Standard 19mm Drive Shaft (3/4") as used on most 6.5hp engines.
BASE CLUTCH - NO SPROCKET INCLUDED
This is a FULLY ADJUSTABLE Race ready twin shoe clutch. Engagment RPM can be adjusted with our NORAM GE spring range from 1820RPM through to 4320RPM.
Supplied with RED springs and Light Shoes for approx 2200RPM engagement.
A full range of springs is available in the GE springs section.
Complete unit with Drum and Clutch. Assembled ready-to-go.
