.jpg)
Product unboxing video.
This is the new model. It suits 2 stroke and 4 stroke karts.
COMPLETE 40mm AXLE ASSEMBLY. EVERYTHING you need to bolt-on and go - including ALL the nuts and bolts WITH ANODISED COUNTERSUNK WASHERS! This is a dream price!
Total Value - $676 (see prices below)
We have decided to make life easy for you and help you out with comparing the prices too. In the brackets ( ) you'll find comparable prices on the net including postage so you can see how much you'll save by buying the whole lot from us. Plus, I bet there's some parts in there you won't get anywhere else!
1x 40mm Axle Shaft ($120)
1x Drilled Brake Disc ($120)
Axle Length: 1050mm
Keyway locations: from end to end:
@ 10mm->75mm
@ 120mm -> 185mm
@ 350mm->400mm
@ 740mm->790mm
@ 975mm -> 1040mm
New. Click the condition meter to learn more about used items.
