Home :: Cleaners & Lubricants :: Cleaners :: Glisten MicroFibre Cloth
Want to get the best out of your GLISTEN products? Easy, grab one of our special micro fibre cloths to ensure a perfect application, every time.
Flawless cleaning - easily.
GLISTEN micro fibre cloths are perfect for applying Glistenproducts. Our cloths make the application of GLISTEN products effective, simplified, and effortless. GLISTEN Cloths can be washed and re-used many times over.
We recommend at least one cloth per GLISTEN product to ensure spot-freeand consistently clean finishes.
I've got old T-Shirts, why use GLISTEN cloths?
Sure, you can use your old T-Shirts to apply GLISTEN products as long as they are 100% cotton and absorbent. But using GLISTEN cloths will result in a consistently cleaner surface using far less effort.
So what's the difference between my old T-Shirts and GLISTEN cloths?
Your cotton T-Shirts are made from a relatively large cotton fibre. These large fibres do not trap the dirt, grime, or oils very well. Because of the special ingredients in Total Paint Care, for instance, a cotton fibre can adequately absorb enough dirt, grime and oil to provide a good finish.
However, a GLISTEN cloth can absorb HUNDREDS of times more dirt, grime & oil. They do this because the micro fibres are so much smaller. The micro fibres are able to attract and retain far more dirt/grime than the large cotton fibres.
GLISTEN cloths will work substantially better, for longer, and remove more dirt, grime, oil, and surplus product from the surface. You'll also notice there is absolutely no residue left behind when you use a GLISTEN cloth to apply GLISTEN products.
50%
SKU GL2
Weight 0.10 kg
Market price: $9.95
Our price: $4.95
GLISTEN ShowSpray
GLISTEN ShowSpray
$17.95
Add your review here
