Home :: Sprockets & Chains :: 219 Pitch Chains :: Go Kart Chain High Performance RLV 219 Pitch 108L BRAND NEW
219 Pitch Chain (108L)
Designed for 2 stroke high performance racing go karts.
Premium RLV quality for racers wanting the absolute best quality chain for their high performance machine.
Our RLV Chains use a patented angular seam bushing formed from strip steel.  These are die-sized around a precison mandrel to create exceptional roundness leading to superior strength and incredible wall thickness consistency.  This produces a chain with lower fatigue rates and extremely low failure rates.
Our RLV chains provide:
- Reduced Joint Wear (stretching/elongation)
- Improved busing endurances (bushing cracking)
- Reduced sprocket wear
- Smoother chain engagement
- Reduced drive system vibration
- Improved chain fatigue resistance
- Improved busines retention (inside chain bar)
- Reduced drive system noise
Suitable for 219P pitch drive systems.
SKU CHNRLV219
Price with FREE DELIVERY: $44.95
Clutch Dry SR Series 35 Pitch 18 Tooth 19mm (3/4inch) bore
Clutch Dry SR Series 35 Pitch 18 Tooth 19mm (3/4inch) bore Sprocket Split Aluminium 35 Pitch 64 Teeth
$39.95
$22.95
Sprocket Split Aluminium 35 Pitch 69 Teeth Go Kart Chain Master Link Joiner 35 Pitch BRAND NEW
$22.95
